Changes between Version 37 and Version 38 of DevWikiDockerTesting
- 03/22/25 20:09:50 (4 days ago)
TabularUnified DevWikiDockerTesting
v37 v38 11 11 12 12 Any one can pull. Here is an example of how to use the docker.osgeo.org for your development. 13 The docker.osgeo.org/postgis/build-test containers are mostly designed for testing lower versions of postgis dependencies and testing upgrades. It contains versions of PostgreSQL 10-15 preinstalled from apt.postgresql.org as well as many prior versions of PostGIS compiled for testing upgrading. It is a hefty image weighing in around 3GB.13 The docker.osgeo.org/postgis/build-test containers are mostly designed for testing lower versions of postgis dependencies and testing upgrades. It contains versions of PostgreSQL 10-15 preinstalled (our older image triquel3) and newer trisquel11 has PostgreSQL 12-17 installed from apt.postgresql.org as well as many prior versions of PostGIS compiled for testing upgrading. It is a hefty image weighing in around 3GB. 14 14 15 15 **FOR DEVELOPMENT**
