Changes between Version 4 and Version 5 of DevWikiAffineParameters
Sep 13, 2011, 10:16:21 AM (13 years ago)
bnordgren
  • DevWikiAffineParameters
    v4 v5
    7171The above matrix equation is shorthand for four equations: one equation each for o,,11,,, o,,12,,, o,,21,, and o,,22,,. We will perform the multiplications on the right hand side one at a time.
    7272
     73[[Image(aggregate_step2.png)]]
     74
     75[[Image(aggregate_step3.png)]]
     76
     77[[Image(aggregate_step4.png)]]
     78
     79 * o,,11,, = s,,x,, ( (1 + k,,x,, k,,y,,) cosθ + k,,y,, sinθ )
     80 * o,,12,, = s,,x,, ( k,,x,, cosθ + sinθ )
     81 * o,,21,, = s,,y,, ( -(1 + k,,x,, k,,y,,) sinθ + k,,y,, cosθ )
     82 * o,,22,, = s,,y,, ( - k,,x,, sinθ + cosθ )
     83
     84Notice that none of the coefficients in the '''O''' matrix may be said to represent pure scaling, rotation or shearing. Rather, they all have components of each of these operations factored in. If a particular transformation is not needed (say there is no shearing in either the x or y directions), then the relevant parameters may be set to zero (k,,x,, = k,,y,, = 0).
     85
     86Also notice that it is not necessary to compute this matrix every time one wants to convert between pixel indices and geographic location. The coefficients are computed once for the entire raster, and may be reused for every pixel calculation. You would use this aggregate matrix '''O''' exactly as you would use any of the individual matrices:
     87
     88[[Image(aggregate_usage.png)]]
    7389
    7490
    75 Starting from the beginning: We want to be able to calculate the
    76 parameters for an affine transform which includes the operations:
    77 scaling, translation, rotation, and skew (shearing). Matrices for
    78 these individual operations are found on
    79 http://en.wikipedia.org/wiki/Transformation_matrix#Examples_in_2D_graphics
    80 . What ho! We can combine these individual operations willy nilly by
    81 matrix multiplication. But note that these individual matrices are the
    82 only places where individual coefficients represent meaningful
    83 parameters. Once you start the multiplication, the coefficients become
    84 all jumbled up with terms combined in various ways.
    85
    86 So, using wikipedia plus a little customization, I've labeled the PURE
    87 coefficients (as opposed to our jumbled coefficients) as follows:
    8891
    8992Sx : scale in the x direction
