Changes between Version 50 and Version 51 of maestro/Downloads
- Nov 25, 2009, 12:06:04 PM (14 years ago)
maestro/Downloads
v50 v51 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r435 7.msi Installer r4357]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r435 7.zip Binaries r4357]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4358.msi Installer r4358] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4358.zip Binaries r4358] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r435 7has the following fixes and additions to 1.0.9:48 r4358 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 99 99 * Added option to add multiple layers to a map (r4347) 100 100 * Added Font Symbol support for points on layers, thanks to Crispin, 1Spatial (r4347) 101 * Fixed a bug in r4347 with saving new resources (r4357) 101 * Build r4357 was broken :( 102 * Fixed a bug in r4347 with saving new resources (r4358) 102 103 103 104 == Previous releases ==
