Changes between Version 46 and Version 47 of maestro/Downloads
- Aug 31, 2009, 10:20:48 AM (15 years ago)
maestro/Downloads
v46 v47 42 42 43 43 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r420 3.msi Installer r4203]45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r420 3.zip Binaries r4203]44 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.msi Installer r4208] 45 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r4208.zip Binaries r4208] 46 46 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 47 47 48 r420 3has the following fixes and additions to 1.0.9:48 r4208 has the following fixes and additions to 1.0.9: 49 49 * Enabled editing of permissions on the root node. 50 50 * Fixed a bug with creating a package from the entire site. … … 92 92 * Fixed various issues with the Search component in WebLayouts (r4203) 93 93 * Added option to read column values in the Expression Editor (r4203) 94 * Fixed a disabled button in the Expression Editor (r4208) 94 95 95 96 == Previous releases ==
