Changes between Version 26 and Version 27 of maestro/Downloads
- Oct 1, 2008, 7:14:35 AM (16 years ago)
maestro/Downloads
v26 v27 39 39 == Preview releases == 40 40 This release may not be functional. It might not be translated completely. It is here to showcase new features or to get feedback on particular issues. Most users do not want to download these files. If you use the installer, you must uninstall a previous version first. If you use the binaries, DO NOT overwrite your current installation, as the next release will not replace your files, and thus not work. Uninstall will even leave the files there. 41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r336 7.msi Installer r3367]42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r336 7.zip Binaries r3367]41 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3368.msi Installer r3368] 42 * [http://download.osgeo.org/mapguide/maestro/MapGuide%20Maestro%20r3368.zip Binaries r3368] 43 43 The number indicates what revision of the source code the items were built with. The [http://trac.osgeo.org/mapguide/log/trunk/Tools/Maestro?verbose=on Revision log] explains what changes are contained in the code. 44 44 45 r336 7has the following fixes and additions to 1.0.9:45 r3368 has the following fixes and additions to 1.0.9: 46 46 * Enabled editing of permissions on the root node. 47 47 * Fixed a bug with creating a package from the entire site.
