Changes between Initial Version and Version 7 of Ticket #1281
- Nov 9, 2010, 3:31:19 PM (14 years ago)
Ticket #1281
- Property Owner set to
- Property Milestone → 2.3
Ticket #1281 – Description
initial v7 1 1 All path in mapviewerphp/layerdefinitionfactory.php pointing to ../../viewerfiles should be corrected to ../viewerfiles 2 2 3 CreateAreaRule can be extended to accept two more parameters, $strokeThickness and $strokeColor.4 CreateLineRule can be extended to accept one more parameter, $strokeThickness3 !CreateAreaRule can be extended to accept two more parameters, $strokeThickness and $strokeColor. 4 !CreateLineRule can be extended to accept one more parameter, $strokeThickness 5 5 6 This two last modifications require to modify accordingly also the areaRule elineRule templates in viewerfiles.6 This two last modifications require to modify accordingly also the areaRule and lineRule templates in viewerfiles. 7 7 8 8 All attached unified diff files refer to <file>_20100226.php (the original one) and <file>.php (the modified one)
