6 | | All aspects of Trac have been designed with the single goal to |
7 | | '''help developers write great software''' while '''staying out of the way''' |
8 | | and imposing as little as possible on a team's established process and |
9 | | culture. |
10 | | |
11 | | As all Wiki pages, this page is editable, this means that you can |
12 | | modify the contents of this page simply by using your |
13 | | web-browser. Simply click on the "Edit this page" link at the bottom |
14 | | of the page. WikiFormatting will give you a detailed description of |
15 | | available Wiki formatting commands. |
16 | | |
17 | | "[wiki:TracAdmin trac-admin] ''yourenvdir'' initenv" created |
18 | | a new Trac environment, containing a default set of wiki pages and some sample |
19 | | data. This newly created environment also contains |
20 | | [wiki:TracGuide documentation] to help you get started with your project. |
21 | | |
22 | | You can use [wiki:TracAdmin trac-admin] to configure |
23 | | [http://trac.edgewall.com/ Trac] to better fit your project, especially in |
24 | | regard to ''components'', ''versions'' and ''milestones''. |
| 5 | == Filing a Bug == |
| 6 | Before filing a bug, review the currently open tickets to make sure that you aren't creating a duplicate. If you have additional information on an issue, you can add it to the ticket. |
27 | | TracGuide is a good place to start. |
28 | | |
29 | | Enjoy! [[BR]] |
30 | | ''The Trac Team'' |
31 | | |
32 | | == Starting Points == |
33 | | |
34 | | * TracGuide -- Built-in Documentation |
35 | | * [http://projects.edgewall.com/trac/ The Trac project] -- Trac Open Source Project |
36 | | * [http://projects.edgewall.com/trac/wiki/TracFaq Trac FAQ] -- Frequently Asked Questions |
37 | | * TracSupport -- Trac Support |
38 | | |
39 | | For a complete list of local wiki pages, see TitleIndex. |
40 | | |
41 | | Trac is brought to you by [http://www.edgewall.com/ Edgewall Software], |
42 | | providing professional Linux and software development services to clients |
43 | | worldwide. Visit http://www.edgewall.com/ for more information. |
