Changes between Version 12 and Version 13 of GoogleSummerCode2022
- Feb 19, 2022, 2:31:24 PM (2 years ago)
v12 v13 60 60 Import / Export Feature for Dbase and ESRI shapefiles: 61 61 62 1) There should be a menu option in the pgAdmin browser tree whenever you right-click a database, table, or schema that allows you to import or export Dbase/shapefiles. 62 1) There should be a menu option in the pgAdmin browser tree whenever you right-click a database, table, or schema that allows you to import or export Dbase/shapefiles. 63 63 64 2) The tool would use the shp2pgsql and pgsql2shp commandlines that are part of the PostGIS source code in much the same way the backup and restore data browse menu options 64 65 built into pgAdmin utilizes pg_dump / pg_restore. It will look for the files in default runtime folder or user specified binary path. 65 66 66 67 3) If a particular table is selected, it will give option to export as a Dbase/Shapefile or import (append to) (no need to ask for table aside from export/import path) or append to 68 67 69 4) If no table is selected - it will pop up a list of tables (as show in export screenshot) and allow user to import a file as a table in currently selected schema. 70 68 71 If no schema is selected it would load in the default schema. 69 72
