Changes between Version 11 and Version 12 of GoogleSummerCode2022
- Feb 19, 2022, 2:28:38 PM (2 years ago)
v11 v12 40 40 For topogeoms, the user would need to specify the table to create, topology, and column, with default column name being ''topo'' if the user does not specify. This will behave more or less the same as geography/geometry loading. For the first pass, we will assume this will just use basic topo element types (areal, lineal, punctal) and will not use subelements. 41 41 42 pgsql2shp will be used to export topogeoms and will use the topo::geometry casting to do so. Since topology tables faces, edges, and nodes are already tables, there is no need to support exporting topology.42 pgsql2shp will be used to export topogeoms and will use the topo::geometry casting to do so. Since topology tables edges and nodes are already geometry tables, there is no need to support exporting topology. However for faces, we might consider allowing exporting that using the topology.GetFace(face_id) function. 43 43 44 44
