Changes between Version 7 and Version 8 of DevWikiWinMingW64_21
09/06/12 19:53:47 (13 years ago)
robe
  • DevWikiWinMingW64_21
    v7 v8
    55PostGIS tests when compiled with GCC 4.6+.  That said you should pick a build lower than GCC 4.6. We like GCC 4.5.4
    66Issues are documented in http://trac.osgeo.org/geos/ticket/518 (also similar issue compiling Geos under windows 64-bit SDK http://trac.osgeo.org/geos/ticket/528 )
     8Also note, the mingw64 for build 32-bit binaries only works for PostgreSQL 9.2+.  There are changes they did in 9.2 that were never backported to 9.1 and below.  so to compile PostGIS for 32-bit you need to use the regular old Msys instructions.
    79
    810== 1. Installing Minimalist GNU for Windows-w64 (MinGW-w64) ==
