Changes between Version 2 and Version 3 of OSSIMVERSIONHistory
- Sep 12, 2008, 12:31:36 PM (16 years ago)
OSSIMVERSIONHistory
v2 v3 3 3 1.7.11 - fixes from user testing and feedback. 4 4 5 # When adding a host to the broadcast section for collaboration, checking the enabled box causes ossimPlanet to hang and crash 6 # Trying to relocate a file pointer in the layers list always results in that layer being moved to the top of the list 7 # When opening images, kmls, etc, the open file dialog defaults to the OSSIM install directory, should default to last opened directory 8 # Open Session dialog box is misnamed Save Session 5 9 10 OMAR 11 12 # The user interface for the Search imagery page is much improved, however same improvements were not made to the video section 13 # In the search results, the word Thumbnail appears before the filename column and there is nothing above the Thumbnail column 6 14 7 15 1.7.10 - OMAR user interface changes, dropped the UDP for navigation in ossimPlanet and went with TCP only.
