Changes between Version 1 and Version 2 of GSoc2013Doc
Sep 12, 2013, 5:33:18 PM (11 years ago)
steve
  • GSoc2013Doc
    v1 v2
    3030'''2. Steps for Testing extend Features of OSGeo4W '''
    3131[[BR]]
    32      * Before you follow this steps you should do all configurations and build the setup.exe at [http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment]
     32     * Before you follow this steps you should do all configurations and build the installer, please go to
     33       [http://trac.osgeo.org/osgeo4w/wiki/SetupDevelopment]
    3334     * execute the following:
    3435       {{{
    35          cd setup
    36          ./bootstrap.sh  --enable-mirror=http://download.osgeo.org/osgeo4w/testing_license # this will produce configure file with a mirror
    37           make # this will produce a setup.exe executable in the setup directory
    38          ./osgeo4w-setup-x86.exe --arch=x86  #this will connect to remote server to get packages from [http://download.osgeo.org/osgeo4w/testing_license/] testing licenses
     36
     37         cd setup   # go to setup directory which you must download of svn server with all sources.
     38
     39         # this will produce configure file with a testing mirror (there are other mirrors for x64)
     40         ./bootstrap.sh  --enable-mirror=http://download.osgeo.org/osgeo4w/testing_license
     41
     42          make # this will produce the osgeo4w-setup-x86.exe installer for x86 machine
     43
     44         ./osgeo4w-setup-x86.exe
     45
    3946       }}}
     47
    4048     * Choose the next option with new feature: Advance Install > Install from internet > Root Directory > Local package directory > Direct connection
    41      * Choose a restrictive package for example 'gdal-mrsid' or 'gdal-ecw' or both(remember if you want to see its license, you must have create it in step one)
    42        and choose another normal package for example: 'gdal-java'.
    43      * Setup will download the license file from remote server into your local directory "Local Package Directory" , you can see it if you want.
    44      * Next step setup.exe will load the file license into a window dialog, with its terms, and If you agree you can continue.
     49     * Choose a restrictive package for example 'gdal-mrsid' or 'gdal-ecw' or both(remember if you want to see its license, you must have create it in
     50       step one) and choose another normal package for example: 'gdal-java'.
     51     * Setup will download the license file from remote server into your local directory "Local Package Directory"/etc/licenses path , you can see it
     52       if you want.
     53     * Next step osgeo4w-setup-x86.exe will load the file license into a window dialog, with its terms, and If you agree you can continue installing.
     54
