Changes between Version 15 and Version 16 of Release/2.5/Notes
- Feb 16, 2013, 11:29:04 AM (11 years ago)
Release/2.5/Notes
v15 v16 44 44 ||Windows Server 2008||Yes+||Yes+|| 45 45 ||Windows Server 2008 R2||N/A||Yes|| 46 ||Windows 8|| Partial1||Partial1||47 ||Windows Server 2012||N/A||Yes (IIS/.NET Tested)||46 ||Windows 8||Yes1||Yes1|| 47 ||Windows Server 2012||N/A||Yes1|| 48 48 49 49 + Not tested, but similar enough to Windows 7 to theoretically work … … 51 51 * IIS configuration will probably not work. Apache config should work due to its self-contained nature 52 52 53 1 IIS configuration does not work, manual configuration allows for install([wiki:ConfigureGuide24Windows Install MapGuide 2.4 on IIS]). Apache config untested53 1 MapGuide 2.5.0.7349: IIS/.Net successfully tested on Windows 8 64-bit and Windows Server 2012. Windows 8 32-bit is similar enough to theoretically work. MapGuide 2.5.0.7345: IIS configuration does not work, manual configuration successfully tested ([wiki:ConfigureGuide24Windows Install MapGuide 2.4 on IIS]). Apache config untested 54 54 55 55 Windows RT (ie. Windows 8 on ARM devices) is not a supported platform for installing MapGuide Open Source
