| 1 | = !MapGuide RFC # - Support Visual Studio 2012 = |
| 2 | |
| 3 | This page contains a change request (RFC) for the !MapGuide Open Source project. |
| 4 | More !MapGuide RFCs can be found on the [wiki:MapGuideRfcs RFCs] page. |
| 5 | |
| 6 | |
| 7 | == Status == |
| 8 | |
| 9 | ||RFC Template Version||(1.0)|| |
| 10 | ||Submission Date||May 17, 2013|| |
| 11 | ||Last Modified||Andy Zhang May 17, 2013|| |
| 12 | ||Author||Andy Zhang|| |
| 13 | ||RFC Status||draft|| |
| 14 | ||Implementation Status||(pending, under development, completed)|| |
| 15 | ||Proposed Milestone||2.6|| |
| 16 | ||Assigned PSC guide(s)||(when determined)|| |
| 17 | ||'''Voting History'''||(vote date)|| |
| 18 | ||+1|||| |
| 19 | ||+0|||| |
| 20 | ||-0|||| |
| 21 | ||-1|||| |
| 22 | ||no vote|| || |
| 23 | |
| 24 | == Overview == |
| 25 | |
| 26 | This RFC updates MapGuide to support Visual Studio 2012. |
| 27 | |
| 28 | == Motivation == |
| 29 | |
| 30 | Supporting the new Visual Studio 2012 will allow a developer to take advantage of the IDE improvements. |
| 31 | |
| 32 | == Proposed Solution == |
| 33 | |
| 34 | * In order to support Visual Studio 2012 new solution and project files will need to be added. |
| 35 | * The Visual Studio 2012 solution files use the same extension as those used by Visual Studio 2010 and so new filenames will need to be used. |
| 36 | * The Visual Studio 2012 project files use the same extension as those used by Visual Studio 2010 and so new filenames will need to be used. |
| 37 | * The proposed new Visual Studio 2012 solution filenames will add "_vs12" to the already existing solution filenames. Example: server_vs12.sln |
| 38 | * The proposed new Visual Studio 2012 project filenames will add "_vs12" to the already existing project filenames. Example: !ServerManager_vs12.vcxproj |
| 39 | |
| 40 | == Implications == |
| 41 | |
| 42 | The existing Visual Studio 2008 and Visual Studio 2010 support will not be changing. Changes to solution files and project files would require that both sets be maintained. |
| 43 | |
| 44 | == Test Plan == |
| 45 | |
| 46 | !Build/Run on Windows and Linux. |
| 47 | |
| 48 | == Funding / Resources == |
| 49 | |
| 50 | Supplied by Autodesk. |
