50 | | || boundary_region || Piemont || region boundary || polygon map || || [http://www.istat.it/it/archivio/24613 ISTAT] |
51 | | || boundary_state || Italy || Italy political map || polygon map || || [http://www.istat.it/it/archivio/24613 ISTAT] |
52 | | || census || Piemont || Piemont census blocks with attributes, clipped || polygon || || TODO |
53 | | || firestations || Piemont || fire stations || points map || || OpenStreetMap |
54 | | || geology || Piemont || Piemont geology map || polygon map || || TODO |
55 | | || geonames || Piemont || geonames || points map || || geonames (should be filtered??) |
56 | | || hospitals || Piemont || Piemont hospitals || points map || || OpenStreetMap |
57 | | || history_markers || Piemont || || || || move to archeology mapset? TODO |
| 50 | || boundary_region || Piedmont || Piedmont boundary || polygon map || || [http://www.istat.it/it/archivio/24613 ISTAT] |
| 51 | || boundary_state || Italy || Italian regions boundaries || polygon map || || [http://www.istat.it/it/archivio/24613 ISTAT] |
| 52 | || census || Piedmont || Piedmont census blocks with attributes, clipped || polygon || || TODO |
| 53 | || firestations || Piedmont || fire stations || points map || || OpenStreetMap |
| 54 | || geology || Piedmont || Piedmont petrology map || polygon map || || [http://webgis.arpa.piemonte.it/geoportalserver_arpa/catalog/search/resource/details.page?uuid=ARLPA_TO:07.02.06-D_2011-06-27:15:23 Piemonte] |
| 55 | || geonames || Piedmont || Piedmont geonames data || points map || || geonames (should be filtered??) |
| 56 | || hospitals || Piedmont || Piedmont hospitals || points map || || OpenStreetMap |
| 57 | || ~~history_markers~~ || Piedmont || || || || move to archeology mapset? TODO |
60 | | || points_of_interest || Piemont || points of interest (examples?) || points map || || beni_ambientali + beni_urbanistici |
61 | | || railroads || Piemont || Piemont railroads || lines map || || [http://www.datigeo-piem-download.it/direct/Geoportale/RegionePiemonte/PPR/ferrovie_mar2010.zip Piemonte] |
62 | | || roadsmajor || Piemont || Piemont major highways and roads || lines map || || autostrade_UTM32_WGS84.shp + strade_statali_UTM32_WGS84.shp |
63 | | || schools || Piemont || schools || points map || || OpenStreetMap (only point data) |
64 | | || streams || Piemont || streams || lines map || || fiumi_UTM_32_WGS84.shp |
65 | | || streets || Piemont || roads and streets || lines map || || strade_comunali_UTM32_WGS84.shp + strade_provinciali_UTM32_WGS84.shp |
66 | | || zipcodes || Piemont || zip codes || polygon map || || TODO |
| 60 | || points_of_interest || Piedmont || Piedmont points of interest || points map || || OpenStreetMap historic + tourism=museum + tourism=artwork |
| 61 | || railroads || Piedmont || Piedmont railroads || lines map || || [http://www.datigeo-piem-download.it/direct/Geoportale/RegionePiemonte/PPR/ferrovie_mar2010.zip Piemonte] |
| 62 | || roadsmajor || Piedmont || Piedmont main roads || lines map || || autostrade_UTM32_WGS84.shp + strade_statali_UTM32_WGS84.shp |
| 63 | || schools || Piedmont || Piedmont schools || points map || || OpenStreetMap (only point data) |
| 64 | || streams || Piedmont || Piedmont streams || lines map || || fiumi_UTM_32_WGS84.shp |
| 65 | || streets || Piedmont || Piedmont minor roads || lines map || || strade_comunali_UTM32_WGS84.shp + strade_provinciali_UTM32_WGS84.shp |
| 66 | || zipcodes || Piedmont || zip codes || polygon map || || TODO |
