Changes between Version 2 and Version 3 of SampleDataset/Italy/Piemont
- Jun 12, 2015, 7:04:37 AM (9 years ago)
v2 v3 12 12 13 13 From [https://en.wikipedia.org/wiki/Piedmont Wikipedia]: Piedmont (/ˈpiːdmɒnt/; Italian: Piemonte, pronounced [pjeˈmonte]; Piedmontese and Occitan: Piemont; French: Piémont) is one of the 20 regions of Italy. It has an area of 25,402 square kilometres (9,808 sq mi) and a population of about 4.6 million. The capital of Piedmont is Turin. 14 15 Data sources: 16 * http://www.dati.piemonte.it/ 17 * http://webgis.arpa.piemonte.it/geoportale/ (WMS/WFS, data, catalogue) 14 18 15 19 === Basic Piemont location with PERMANENT mapset === … … 29 33 30 34 || '''name''' || '''area''' || '''description''' || '''resolution''' ||'''rows x columns (cells)''' || '''note''' || 31 || basins || Piemont || Watersheds derived from xxx || std || std || TODO 35 || basins || Piemont || Watersheds derived from xxx || std || std || TODO (r.watershed on elevation) 32 36 || elevation || Piemont || Elevation GMTED2010 || std || std || gmted2010_utm32wgs84.tif 33 37 || elevation_shade || Piemont || Shaded relief || std || std || gmted2010_shaded_utm32wgs84.tif 34 || geology || Piemont || Geology derived from a vector map || std || std || TODO 35 || lakes || Piemont || Piemont lakes || std || std || TODO 38 || geology || Piemont || Geology derived from a vector map || std || std || TODO - use "BDGeo100 - Litologia"? 39 || lakes || Piemont || Piemont lakes || std || std || TODO: from OSM? 36 40 || landuse || Piemont || Landuse in 2007 || std || std || eea_corine_2007_100m_piemonte.tif 37 41 || orthophoto || Orbassano|| orthophoto (R, G, B, NIR) || 1m res or better || || orbassano_orto_rgb.tif, orbassano_orto.tfw, orbassano_orto.tif (NIR: TODO) 38 || soils || Piemont || soil type || || || should be vector data? TODO 42 || soils || Piemont || soil type || || || should be vector data? TODO: no access to "Cartografia dei suoli"! 39 43 40 44 ==== Vector maps ==== … … 43 47 || buildings || Orbassano || building footprints || polygon/faces map || || edifici_osm_UTM_32_WGS84.shp 44 48 || boundary_municipalities|| Piemont || Piemont municipalities map || polygon map || || comuni_UTM_32_WGS84.shp 45 || boundary_region || Piemont || region boundary || polygon map || || TODO 46 || boundary_state || Italy || Italy political map || polygon map || || TODO: get from ISTAT49 || boundary_region || Piemont || region boundary || polygon map || || TODO: get from [http://www.istat.it/it/archivio/24613 ISTAT] 50 || boundary_state || Italy || Italy political map || polygon map || || TODO: get from [http://www.istat.it/it/archivio/24613 ISTAT] 47 51 || census || Piemont || Piemont census blocks with attributes, clipped || polygon || || TODO 48 52 || firestations || Piemont || fire stations || points map || || TODO 49 || geology || Piemont || North Carolinageology map || polygon map || || TODO50 || geonames || Piemont || geonames || points map || || TODO 51 || hospitals || Piemont || North Carolinahospitals || points map || || TODO53 || geology || Piemont || Piemont geology map || polygon map || || TODO 54 || geonames || Piemont || geonames || points map || || TODO: toponimi 55 || hospitals || Piemont || Piemont hospitals || points map || || TODO 52 56 || history_markers || Piemont || || || || move to archeology mapset? TODO 53 57 || parcels || for CC or rural area || || polygon map || || TODO 54 58 || points_bare_surface || CC or rural || points map || bare ground lidar points for interpolation || || TODO 55 59 || points_of_interest || Piemont || points of interest (examples?) || points map || || TODO 56 || railroads || Piemont || Piemont railroads || lines map || || TODO 60 || railroads || Piemont || Piemont railroads || lines map || || TODO: from OSM? 57 61 || roadsmajor || Piemont || Piemont major highways and roads || lines map || || autostrade_UTM32_WGS84.shp + strade_provinciali_UTM32_WGS84.shp + strade_statali_UTM32_WGS84.shp 58 62 || schools || Piemont || schools || points map || || TODO 59 63 || streams || Piemont || streams || lines map || || fiumi_UTM_32_WGS84.shp 60 || streets || Piemont || roads and streets || lines map || || TODO 64 || streets || Piemont || roads and streets || lines map || || TODO: from OSM? 61 65 || zipcodes || Piemont || zip codes || polygon map || || TODO 62 66
