| 1 | = GRASS GIS 7.2.3 = |
| 2 | |
| 3 | [[TOC]] |
| 4 | |
| 5 | A short summary of changes: '''[wiki:Grass7/NewFeatures72 New features in GRASS 7.2]''' (note: current is '''[wiki:Grass7/NewFeatures74 New features in GRASS 7.2]''') |
| 6 | |
| 7 | |
| 8 | === Releases === |
| 9 | |
| 10 | ==== Stable Release ==== |
| 11 | |
| 12 | * ~~Release date: ''XX YYY 2018''~~ |
| 13 | * ~~Announcement: tbd~~ |
| 14 | * ~~Changelog: https://grass.osgeo.org/grass72/source/ChangeLog_7.2.3.gz~~ |
| 15 | * ~~Binaries: https://grass.osgeo.org/download/software/#G72x~~ |
| 16 | * ~~Source code: https://grass.osgeo.org/grass72/source/grass-7.2.3.tar.gz ([https://grass.osgeo.org/grass72/source/grass-7.2.3.md5sum md5sum])~~ |
| 17 | * ~~SVN Source Code Checkout 7.2.3:~~ |
| 18 | {{{ |
| 19 | svn checkout https://svn.osgeo.org/grass/grass/tags/release_2018XXYY_grass_7_2_3 |
| 20 | }}} |
| 21 | |
| 22 | ==== Release Candidate 1 (RC1) ==== |
| 23 | |
| 24 | * ~~Release date: ''XX YYY 2018''~~ |
| 25 | * ~~Changelog: https://grass.osgeo.org/grass72/source/ChangeLog_7.2.3RC1.gz~~ |
| 26 | * ~~Binaries: https://grass.osgeo.org/download/software/#G72x~~ |
| 27 | * ~~Source code: https://grass.osgeo.org/grass72/source/grass-7.2.3RC1.tar.gz ([https://grass.osgeo.org/grass72/source/grass-7.2.3RC1.md5sum md5sum])~~ |
| 28 | * ~~SVN Source Code Checkout 7.2.3RC1:~~ |
| 29 | {{{ |
| 30 | svn checkout https://svn.osgeo.org/grass/grass/tags/release_2018XXYY_grass_7_2_3RC1 |
| 31 | }}} |
| 32 | |
| 33 | === SVN Source Code === |
| 34 | |
| 35 | * Milestone: [milestone:"7.2.3"] |
| 36 | * SVN Checkout latest 7.2 release branch (including yet unpublished bugfixes): |
| 37 | {{{ |
| 38 | svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_7_2 |
| 39 | }}} |
| 40 | |
| 41 | === Overview of changes === |
| 42 | |
| 43 | A series of new features and stability fixes, manual improvements, and a few language translations have been added. |
| 44 | |
| 45 | The GRASS GIS 7.2.3 release provides '''more than 710 fixes and improvements''' with respect to the stable release 7.2.0. |
| 46 | |
| 47 | ==== New modules ==== |
| 48 | |
| 49 | * n/a |
| 50 | |
| 51 | ==== Major module changes ==== |
| 52 | |
| 53 | (see also below for closed bugs) |
| 54 | |
| 55 | * n/a |
| 56 | |
| 57 | ==== Minor module changes ==== |
| 58 | |
| 59 | (see also below for closed bugs) |
| 60 | |
| 61 | * grass startup script: added version output 'grass72 --config version' |
| 62 | * G72:d.mon: notes on functionality added |
| 63 | * G72:i.vi: fix typo in ndvi from Sentinel bands |
| 64 | * G72:r.in.srtm: Print an error not fail in XY location |
| 65 | * G72:r.out.gdal: export inf values |
| 66 | * G72:r.random.surface: rename variable Surface to RSurface to avoid compiler error |
| 67 | * G72:r.stream.extract: remove problematic infinity as default, use 64 bit integer to support large regions … |
| 68 | * G72:r.viewshed: fix binary output |
| 69 | * G72:r.watershed: reduce chance of integer overflow |
| 70 | * G72:t.rast.mapcalc and t.rast.algebra: manual edits (trunk, r71879) |
| 71 | * G72:v.external manual: limitations added |
| 72 | * G72:v.external: mixed up IDs from PostGIS tables, fixes #3248 |
| 73 | * G72:v.import: do not snap by default |
| 74 | * G72:v.info: Added layer specific database information to extended metadata |
| 75 | * G72:v.voronoi: update parameter description |
| 76 | |
| 77 | === Improvements in the Graphical User Interface === |
| 78 | |
| 79 | * ... |
| 80 | |
| 81 | === Scripting === |
| 82 | |
| 83 | * ... |
| 84 | |
| 85 | === Projection support === |
| 86 | |
| 87 | * ... |
| 88 | |
| 89 | === Library changes === |
| 90 | |
| 91 | * use GEOS C API (#3421). Credits to Bas Couwenberg |
| 92 | * diglib: fix bug caused by compiler optimizations |
| 93 | * iostreamlib: fix memory manager |
| 94 | * pythonlib: add addon bin dir to path on all platforms |
| 95 | * rasterlib: Eliminate RPC/XDR dependency from raster library |
| 96 | |
| 97 | === Improvements in the Graphical User Interface === |
| 98 | |
| 99 | * G72:wxGUI: fix WMS service in latlong locations |
| 100 | |
| 101 | === User Manuals - Documentation === |
| 102 | |
| 103 | * Various manual pages: new screenshots added, thanks to [https://grasswiki.osgeo.org/wiki/GRASS_GCI_Ideas_2017 Google Code-in] |
| 104 | * added missing height HTML tags according to submitting rules (needed for wxGIU html browser |
| 105 | |
| 106 | === Message Translations === |
| 107 | |
| 108 | * Translations now managed in Transifex (please join and translate messages): https://www.transifex.com/grass-gis/grass72 |
| 109 | |
| 110 | === Dockerfile === |
| 111 | |
| 112 | * Updated, docker image e.g. available at https://hub.docker.com/r/neteler/grassgis7/ |
| 113 | |
| 114 | === New Addons since GRASS 7.2.2 === |
| 115 | |
| 116 | * G7A:... |
| 117 | |
| 118 | === Closed tickets === |
| 119 | |
| 120 | ==== Closed bugs since the last release ==== |
| 121 | |
| 122 | [[TicketQuery(status=closed&milestone=7.2.3&type=defect&resolution=fixed&order=priority)]] |
| 123 | |
| 124 | ==== Closed wishes since the last release ==== |
| 125 | |
| 126 | [[TicketQuery(status=closed&milestone=7.2.3&type=enhancement&resolution=fixed&order=priority)]] |
| 127 | |
