Changes between Version 4 and Version 5 of Release/7.0.3-News
- Dec 18, 2015, 5:12:10 AM (9 years ago)
Release/7.0.3-News
v4 v5 42 42 ==== Minor module changes ==== 43 43 44 * G7:g.remove: print warning when no files found 45 * G7:g.proj: don't ignore epsg as parameter when printing info (-p/g) 46 * G7:r.watershed: fix correction for diagonal flow bias 47 * temporal framework: Added output and region flag to t.rast.univar 48 * G7:v.generalize: add test for self-intersection 49 * G7:v.import: show reprojection progress; catch exception when unable to open datasource 50 * G7:v.in.ogr: backport -j flag; add new parameters "epsg" and "datum_trans" 51 * G7:v.rast.stats: fix handling column prefixes 52 * G7:v.surf.bspline: move opening raster after opening driver 53 * G7:v.what.rast: exit when no features of given type found 44 54 * G7:v.what.strds: new flag to update attribute table of input vector map 55 45 56 ==== GUI changes ==== 57 58 * wxGUI/colortable: fix saving color table to file 59 * wxGUI/modeler: fix setting parametrized options multiple times 60 * wxGUI: fix launching v.krige 46 61 47 62 ==== Library changes ==== … … 49 64 ==== PyGRASS changes ==== 50 65 66 * grass.py: fix initialization script when gis_set.py is not available 67 51 68 ==== Map projection changes ==== 52 69 53 70 ==== Portability changes ==== 54 71 72 * grass.desktop: high res icons added, Debian specific xpm removed 73 * Makefile system: add soname on linux 74 55 75 ===== MS Windows ===== 56 76 57 * Proj.4 library upgraded to 4.9.2 58 * winGRASS 64 bit support 77 * Proj.4 library (included in binary) upgraded to 4.9.2 78 * winGRASS 64 bit support (via [http://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe OSGeo4W 64bit Installer]) 79 59 80 ==== Manual pages ==== 60 81 82 * Examples added to various manual pages 83 61 84 ==== Message translation updates ==== 85 86 * French messages updated 62 87 63 88 === Closed tickets ===
