Changes between Version 36 and Version 37 of Grass7/NewFeatures78
- Jun 23, 2021, 5:06:37 AM (3 years ago)
v36 v37 209 209 There are numerous new addons which enlarge the already impressive list of addons available (see http://grass.osgeo.org/grass7/manuals/addons/): 210 210 211 * G7A:i.landsat toolset: G7A:i.landsat.download, G7A:i.landsat.import, G7A:i.landsat.qc 211 212 * G7A:i.sar.speckle - Remove speckle from SAR image 213 * G7A:m.csv.clean: Cleaning of CSV files 214 * G7A:r.bearing.distance: Find the bearing and/or straight-line distance from all non-null cells to the specified point. 215 * G7A:r.centroids: Creates vector map of centroids from raster of "clumps". 216 * G7A:r.extract: Extracts specified categories of an integer input map. 212 217 * G7A:r.fill.category - Replaces the values of pixels of a given category with values of the surrounding pixels 218 * G7A:r.in.ogc, G7A:r.in.ogc.coverages: OGC API support 213 219 * G7A:r.mapcalc.tiled - Runs r.mapcalc in parallel over tiles 214 220 * G7A:r.object.thickness - Evaluates minimum, maximum and mean thickness of objects of a given category on a raster map … … 218 224 * G7A:r.sample.category - Create sampling points from each category in a raster map 219 225 * G7A:r.series.diversity - Compute diversity indici over input layers 226 * G7A:r.skyline: Compute the skyline index and / or find the horizon cells in a raster viewshed. 220 227 * G7A:r.slope.direction - Calculates slope following a direction raster 221 228 * G7A:r.zonal.classes - Calculates zonal classes proportion describing raster areas's composition, e.g., in terms of land-cover classes 222 229 * G7A:v.in.csv: Easy import of CSV as vector points 230 * G7A:v.in.ogc, G7A:v.in.ogc.coverages: OGC API support 231 * G7A:v.percolate: Continuum percolation analysis 223 232 == Migrating from GRASS GIS 6 to version 7.x == 224 233
