Changes between Version 5 and Version 6 of BuildingOnWindows
- Jun 18, 2008, 2:35:35 AM (16 years ago)
BuildingOnWindows
v5 v6 15 15 You don't need to build GRASS in order to build your own modules; the smartest way is to: 16 16 17 (2a) download and install the current WinGRASS release (6.3.0-3). Referring to the following building guide (http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html):17 (2a) download and install the current WinGRASS release. Referring to the following building guide (http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html): 18 18 19 19 (2b) execute steps 1 and 2 from that document 20 20 21 (2c) jump to step 24, download and extract the GRASS sources tarball (it's very important that you use the same sources as the current binary release , that is 6.3.0) as suggested by the guide.21 (2c) jump to step 24, download and extract the GRASS sources tarball (it's very important that you use the same sources as the current binary release) as suggested by the guide. 22 22 23 23 (2d) run the configure as suggested by the guide and run the "export PATH=[...]" command
