Changes between Version 4 and Version 5 of BuildingOnWindows
- Jun 18, 2008, 2:34:46 AM (16 years ago)
BuildingOnWindows
v4 v5 7 7 == develop your own GRASS modules on MS-Windows == 8 8 9 (1) download this archive: http://grass.osgeo.org/grass63/binary/mswindows/native/GRASS_MSYS_Environment.zip . It is still not updated, but it's fair enough for your job.9 (1) download this archive: http://grass.osgeo.org/grass63/binary/mswindows/native/GRASS_MSYS_Environment.zip 10 10 11 (2) refer to this document on how to develop GRASS modules: http://download.osgeo.org/grass/grass6_progman/ . You don't need to build GRASS to build your own modules; the smartest way is to: 11 It is still not updated, but it's fair enough for the job. 12 12 13 (2a) download and install the current WinGRASS release (6.3.0-3). Refer to my building guide (http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html): 13 (2) refer to this document on how to develop GRASS modules: http://download.osgeo.org/grass/grass6_progman/ 14 15 You don't need to build GRASS in order to build your own modules; the smartest way is to: 16 17 (2a) download and install the current WinGRASS release (6.3.0-3). Referring to the following building guide (http://www.webalice.it/marco.pasetti/grass/BuildFromSource.html): 14 18 15 19 (2b) execute steps 1 and 2 from that document … … 21 25 (2e) run: make libs 22 26 23 (3) assuming that you have your own module * v.in.daniel* in C:\msys\local\src\my-grass-modules\v.in.daniel:27 (3) assuming that you have your own module *example.module* in C:\msys\local\src\my-grass-modules\example.module: 24 28 25 (3a) go to your module's source root: cd /usr/local/src/my-grass-modules/ v.in.daniel29 (3a) go to your module's source root: cd /usr/local/src/my-grass-modules/example.module 26 30 27 (3b) run: make MODULE_TOPDIR=/usr/local/src/grass-6.3.0 <BR> 31 (3b) run: make MODULE_TOPDIR=/usr/local/src/grass-6.3.0 32 28 33 your own module's binaries will be built in: C:\msys\local\src\grass-6.3.0\dist.i686-pc-mingw32\bin 29 34 while the html help pages in: C:\msys\local\src\grass-6.3.0\dist.i686-pc-mingw32\docs\html
