Changes between Initial Version and Version 2 of Ticket #1355
05/03/11 10:42:50 (14 years ago)
martinl
Hopefully fixed in r46171.
BTW, vector digizer in 6.4.2+ needs some testing. The component has been recently ported from C++ to Python. It would be good to catch & fix major part of possible bugs before we release 6.4.2 as the first version with working wxGUI vector digitizer (including winGRASS).
Martin
  • Ticket #1355
    • Property Component wxGUIPython ctypes
    • Property Keywords G_gisinit() added; v.digit removed
    • Property Cc grass-dev@… added
    • Property Milestone 6.5.06.4.2
    • Property Owner changed from grass-dev@… to martinl
    • Property Status newassigned
  • TabularUnified Ticket #1355 – Description
    initial v2
    1 This error is printed to the Layer Manager output window when I try to start editing an existing vector. I select "Digitize" from the drop-down box on the Map Display, and then select the name of my vector under the left-most drop-down box in the Map Display. The Map Display doesn't draw any of my GIS layers, but goes completely white at this point.
     1This error is printed to the Layer Manager o utput window when I try to start editing an existing vector. I select "Digitize" from the drop-down box on the Map Display, and then select the name of my vector under the left-most drop-down box in the Map Display. The Map Display doesn't draw any of my GIS layers, but goes completely white at this point.
    33I have rebuilt the vector topology, but the error still occurs. I have tested the wxgui digitizer in a different mapset with a different vector, with the same error occurring.
