Changes between Version 6 and Version 7 of WikiStart/DiscussionZone/ReleasePlanOnePointSix
- 06/20/12 07:52:45 (13 years ago)
v6 v7 29 29 The following libraries (version) are packaged with !GeoPrisma 1.6 : 30 30 31 * !OpenLayers ( 2.11)31 * !OpenLayers ('''2.12-rc7, updated''') 32 32 * Proj4js (1.0.1) 33 33 * !MapFish (trunk, revision 3862) … … 63 63 64 64 * !GoogleMaps (3.5+) 65 * !YahooMaps (3.0+)66 65 * !OpenStreetMaps 66 67 The following tile providers are deprecated in this release of !GeoPrisma : 68 69 * !YahooMaps ('''deprecated''') 67 70 68 71 === Widgets === … … 128 131 * mapfishlayertree 129 132 * mapfishrecenter 133 134 === Migration Guide : !GeoPrisma 1.4 to 1.6 === 135 136 * !Openlayers 2.11 is not longer supported. If you do not use !GeoPrisma included libraries, you need to upgrade to !OpenLayers 2.12-rc7. 137 138 === Other notes === 139 140 * !OpenLayers 2.12-rc7 is now used, which has many files that were deprecated and moved to a single deprecated.js file inside its lib directory. This file is included when using the printAllLibSources with pVersion parameter equal to 'deprecated'.
