Changes between Version 10 and Version 11 of Release/1.2/Notes
01/27/12 08:05:48 (13 years ago)
adube
  • TabularUnified Release/1.2/Notes
    v10 v11
    120120'''API widget'''
    121121
    122 The API is a new widget that was added (#389). It is automatically added to the UI and doesn't need to be defined in the configuration file.  However, it must still be included in the .xslt template file
     122The API is a new widget that was added (#389). It is automatically added to the UI and doesn't need to be defined in the configuration file.  However, it must still be included in the .xslt template file, so it is mandatory that you do so for your template files otherwise you'll receive an error from the xslt processor.
    123123
    124124'''!GoogleMaps'''
    125125
    126 !GoogleMaps v2 is no longer supported in 1.2 (#176). You must change all source tags in your gymo services with google provider to point to a v3 url instead.
     126!GoogleMaps v2 is no longer supported in 1.2 (#176). You must change all source tags in your gymo services that have the google provider to point to a v3 url instead.
    127127
    128128'''!InitialView'''
