Changes between Version 3 and Version 4 of Bolsena2013
05/02/13 00:59:25 (12 years ago)
fxp
  • Bolsena2013
    v3 v4
    1010== Code Sprint Proposals ==
    1111This section contains ideas for development projects we can work on during the code spring
    12
     12
    1313 * '''Catalog Consistency Report''' - A service that will analyze each metadata and create a report for all (or a subset) of metadata in the catalog.
    1414  * The analysis would find all service metadata that reference a metadata, check that all data metadata still exist in the service and check to see if new metadata should be created.  The analysis would also check information like bounding box, SRS, keywords, etc... and report on inconsistencies.
    1515  * The report would contain a list of all the errors detected and provide quick-fix links.
    1616 * '''Mobile UI''' - Create a prototype mobile UI for GeoNetwork.  An adaptive UI would be idea.  Perhaps modifying current implementations to be more adaptive to a variety of screen sizes.
     17 * '''Cleaning session'''
     18  * Remove GAST (103Mo) ?
     19  * Drop Mckoi support (WEB-INF/db, config.xml, !McKoiActivator, doc references) ?
     20  * JS libs : Could we share common libs with classic and widget UI ? classic using old version of GeoExt, OpenLayers
     21  * Update !GeoServer to latest release ?
    1722
    1823== Presentations ==
