Changes between Version 25 and Version 26 of WCS+interoperability
- Nov 14, 2017, 7:14:48 AM (7 years ago)
v25 v26 21 21 || ||= 1.0 =||= 1.1 =||= 2.0 =|| 22 22 ||= ArcGIS =|| Result with normal CRS: OK || Result with normal CRS: !GridOffsets must dx,dy, i.e., without 0,0 || Result with normal CRS: Only scaleFactor seems to be supported. GDAL fails if the returned raster does not have the anticipated size. || 23 ||= !GeoServer =|| Result with normal CRS: OK, with inverted axis CRS: OK || The bounding box should contain the cell areas. !GridOffsets should be according to the standard (for inverted CRS that is 0,dy,dx,0 and dy usually negative) except that it seems dx and dy must be multiplied by -1|| Inverted CRS: subset axes need to be inverted, grid axis order should not be swapped although sequence order says so ||23 ||= !GeoServer =|| Result with normal CRS: OK, with inverted axis CRS: OK || The bounding box should contain the cell areas. If !GridOffsets is set to "0,dx,dy,0" for inverted CRS, the result is very close to expected but slightly different size (in a test 59x38 instead of 60x38) || Inverted CRS: subset axes need to be inverted, grid axis order should not be swapped although sequence order says so || 24 24 ||= !MapServer =|| Results with inverted axis CRS: OK || Results with inverted axis CRS: !GridOffsets must be abs(dx),abs(dy), i.e., without 0,0 and positive. GridCRS coordinates should not be inverted. || Results with inverted axis CRS: Grid axis labels must not be swapped; Grid otherwise ok since no coverageFunction || 25 25 ||= Rasdaman =|| Not supported || Not supported || Results with inverted axis CRS: OK ||
