Changes between Version 13 and Version 14 of WCS+interoperability
- Nov 13, 2017, 5:43:26 AM (7 years ago)
v13 v14 20 20 21 21 || ||= 1.0.0 =||= 1.1.0 =||= 1.1.1 =||= 1.1.2 =||= 2.0.1 =|| 22 ||= ArcGIS =|| 1.0.0 || 1.1.0 with normal CRS, with inverted axis CRS || 1.1.1 with normal CRS, with inverted axis CRS || 1.1.2 with normal CRS, with inverted axis CRS || 2.0.1 with normal CRS, with inverted axis CRS||22 ||= ArcGIS =|| OK || Result with normal CRS: !GridOffsets must dx,dy, i.e., without 0,0 || same as 1.1.0 || same as 1.1.0 || Only scaleFactor seems to be supported. GDAL fails if the returned raster does not have the anticipated size. || 23 23 ||= !GeoServer =|| 1.0.0 || 1.1.0 with normal CRS, with inverted axis CRS || 1.1.1 with normal CRS, with inverted axis CRS || 1.1.2 with normal CRS, with inverted axis CRS || 2.0.1 with normal CRS, with inverted axis CRS || 24 ||= !MapServer =|| OK || Results with inverted axis CRS: !GridOrigin must be maxY,minX; !GridOffsets must be dx,abs(dy). || same as 1.1.0 || same as 1.1.0 || Results with inverted axis CRS: Grid axis labels must not be swapped; Grid otherwise ok since no coverageFunction ||24 ||= !MapServer =|| OK || Results with inverted axis CRS: !GridOrigin must be maxY,minX; !GridOffsets must be abs(dx),abs(dy), i.e., without 0,0 and positive. || same as 1.1.0 || same as 1.1.0 || Results with inverted axis CRS: Grid axis labels must not be swapped; Grid otherwise ok since no coverageFunction || 25 25 ||= Rasdaman =|| Rasdaman does not support || Rasdaman does not support || Rasdaman does not support || Rasdaman does not support || OK || 26 26
