Changes between Initial Version and Version 4 of Ticket #770
- Apr 2, 2007, 9:29:24 PM (17 years ago)
Ticket #770
- Property Cc added
- Property Component OGR_SRS → OGR_SF
- Property Priority high → normal
- Property Milestone → 1.5.0
- Property Owner changed from to
Ticket #770 – Description
initial v4 1 When we import data to postgis using ogr2ogr, ogr doesn't fill the proj4text field of the spatial_ref_sys table. This cause problem when you want to use the transform(geometry,int) function of postGIS. 1 2 {{{ 2 When we import data to postgis using ogr2ogr, ogr doesn't fill the proj4text3 field of the spatial_ref_sys table. This cause problem when you want to use the4 transform(geometry,int) function of postGIS.5 6 3 See : 7 4 http://postgis.refractions.net/pipermail/postgis-users/2005-February/006953.html
