5 | | The result seem to be good as first glance, but problems appear as i perform a slope analysis on another software (either arcmap or QGis). Look the two attached file, one is the analysis on the original data and the other the reprojected data. You can clearly see some artefacts on the image. |
| 5 | The result seem to be good as first glance, but problems appear as i perform a slope analysis on tjhe resulting file with either arcmap or QGis. Look the two attached file: |
| 6 | - slope_analysis_without_artefact.PNG is the analysis performed one the original data |
| 7 | - slope analysis with artefacts.PNG​ is the analysis performed on the reprojected data. You can clearly see some artefacts on the image. |
