1 | | Hello, I use gdal v1.9.0. I tried to build virtual datasets by gdal and got a different behaviour gdalwarp on the Linux and Windows platforms. |
2 | | At the Windows is all ok, but on the Linux platform I got a final vrt without a tag <ColorInterp>Gray</ColorInterp> (this tag exists in the final vrt if I launch gdal under Windows). This tag is very critical for my application. How can I fix this problem? |
| 1 | I'm sorry. I have really different version of gdal. But I'm at a loss. |
| 2 | I do command gdalwarp --version and got a same result: |
| 3 | GDAL 1.9.0, released 2011/12/29 at the Windows and Linux machines. |
| 4 | But at the Windows I downloaded ready to use binaries package from the: |
4 | | See attachments to get a cube_face.vrt in the Linux and Windows platforms and compare it. |
| 6 | http://www.gisinternals.com/sdk/PackageList.aspx?file=release-1500-dev.zip |
| 7 | |
| 8 | At the Linux I'm downloaded sources and built it from the: |
| 9 | |
| 10 | http://download.osgeo.org/gdal/gdal-1.9.0.tar.gz |
| 11 | |
| 12 | It is really a different version of the gdal and gives different results, despite the fact that gdalwarp --version gives the same version. |
| 13 | |
| 14 | I tried to build |
| 15 | |
| 16 | http://download.osgeo.org/gdal/gdal-1.9.0.tar.gz at the Windows and |
| 17 | |
| 18 | finally got the same result in the Windows and Linux machines. |
| 19 | How is it possible? |
| 20 | |
| 21 | I want to ask one more question: What about the errors: |
| 22 | |
| 23 | ERROR 1: tolerance condition error |
| 24 | ERROR 1: Reprojection failed, err = -20, further errors will be supressed on the |
| 25 | transform object. |
| 26 | |
| 27 | When you run my example? |
