Changes between Initial Version and Version 1 of Ticket #2780
- Jan 13, 2009, 12:16:39 PM (15 years ago)
Ticket #2780
- Property Cc added
- Property Component Utilities → GDAL_Raster
- Property Priority high → normal
- Property Owner changed from to
- Property Keywords GEORASTER added
Ticket #2780 – Description
initial v1 16 16 17 17 1. Using a simple GeoTIFF file (test.tif), in WGS84 lat/lon projection/datum, over California, I ran this gdal_translate command: 18 18 {{{ 19 19 $ gdal_translate -of georaster test.tif georaster:scott/tiger,,landsat,scene -co "DESCRIPTION=(ID NUMBER, SITE VARCHAR2(45), SCENE MDSYS.SDO_GEORASTER)" -co "INSERT=VALUES(1,'Test Image', SDO_GEOR.INIT())" 20 20 }}} 21 21 2. Here is the results of running the command in #1 above: 22 22 {{{ 23 23 Input file size is 873, 578 24 24 0...10...20...30...40...50...60...70...80...90...100 - done. … … 28 28 ORA-06550: line 17, column 3: 29 29 PL/SQL: Statement ignored 30 30 }}} 31 31 3. It appears that the GeoTIFF file imported for the most part, but an Oracle error/exception was thrown on GENERATESPATIALEXTENT which bombed gdal_translate. 32 32 … … 39 39 40 40 *** gdalinfo on test.tif output: 41 41 {{{ 42 42 $ gdalinfo test.tif 43 43 Driver: GTiff/GeoTIFF … … 78 78 Band 5 Block=64x64 Type=Byte, ColorInterp=Undefined 79 79 Band 6 Block=64x64 Type=Byte, ColorInterp=Undefined 80 80 }}} 81 81 82 82 thanks,
