Changes between Version 7 and Version 8 of FDORfc59
- Apr 10, 2011, 3:48:25 PM (13 years ago)
FDORfc59
v7 v8 96 96 97 97 98 === IEllipticalArcSegment ===98 === Class FdoIEllipticalArcSegment === 99 99 100 100 {{{ … … 144 144 /// 145 145 virtual const double * GetFocalPositionOrdinates() = 0; 146 }; 147 }}} 146 148 149 150 === Class FdoICircleSegment === 151 152 /// \brief 153 /// The FdoICircleSegment class represents a circle as an arc whose ends 154 /// coincide to form a simple closed loop. The three control positions shall be 155 /// distinct non-co-linear positions for the circle to be unambiguously defined. 156 /// The arc is simply extended past the third control position until the first 157 /// control position is encountered. 158 /// 159 /// \remarks 160 /// Circle segments cannot be defined as non-closed segments. 161 /// If describing a circle where the start and end points are identical 162 /// the mid-point is the diametrically opposite point on the circle. 163 /// 164 class FdoICircleSegment : public FdoIArcSegmentAbstract 165 { 147 166 protected: 148 167 … … 150 169 /// Constructs a default instance. 151 170 /// 152 FdoI EllipticalArcSegment() {};171 FdoICircleSegment() {}; 153 172 154 173 /// \brief 155 174 /// Default destructor. 156 175 /// 157 virtual ~FdoI EllipticalArcSegment() {};176 virtual ~FdoICircleSegment() {}; 158 177 }; 159 }}}160 161 162 178 163 179
