Changes between Version 6 and Version 7 of FDORfc59
Apr 10, 2011, 3:45:41 PM (13 years ago)
gregboone
  • FDORfc59
    v6 v7
    9393    FdoGeometryComponentType_CircleSegment = 137
    9494};
     95}}}
     96
     97
     98=== IEllipticalArcSegment  ===
     100{{{
     101/// \brief
     102/// The FdoIEllipticalArcSegment class represets an Elliptical Arc Segment
     103/// geometry type. EllipticalArcSegment can describe portions of, or a full
     104/// ellipse. If describing a full ellipse, the start and end points are identical
     105/// and the mid-point is the diametrically opposite point on the ellipse.
     106///
     107/// \remarks
     108/// Two foci were specified as opposed to major/minor axes so that the
     109/// API can derive this class from ArcSegmentAbstract and CurveSegmentAbstract,
     110/// thus reusing the concepts of start/mid/end points as defined in the base
     111/// classes. In this manner the API can maintain a common look/feel when defining
     112/// arc types. The expectation is that a Geometry API utility method will be
     113/// provided that will allow conversion to major/minor axis.
     114///
     115/// The semimajor axis and the semiminor axis are one half of the major and minor
     116/// diameters, respectively. These are sometimes called the major and minor semi-axes,
     117/// the major and minor semiaxes,or major radius and minor radius.
     118///
     119/// The foci of the ellipse are two special points on the ellipse's major
     120/// axis and are equidistant from the center point. The sum of the distances from any
     121/// point on the ellipse to those two foci is constant and equal to the major
     122/// diameter. Each of these two points is called a focus of the ellipse.
     123///
     124class FdoIEllipticalArcSegment : public FdoIArcSegmentAbstract
     125{
     126public:
     127
     128    /// \brief
     129    /// Gets the two focal positions of this Ellipse Geometry.
     130    ///
     131    /// \return
     132    /// Returns the two focal positions of the Ellipse as a collection
     133    /// of two positions.
     134    ///
     135    virtual FdoIDirectPositionCollection const * GetFocalPositions() const = 0;
     136
     137    /// \brief
     138    /// Gets the two focal positions of this Ellipse Geometry as an array.
     139    /// The ordinates are in the order XYZMXYZM, with only those present
     140    /// according to the dimensionality.
     141    ///
     142    /// \return
     143    /// Returns the two focal positions of the Ellipse as a collection
     144    ///
     145    virtual const double * GetFocalPositionOrdinates() = 0;
     146
     147protected:
     148
     149    /// \brief
     150    /// Constructs a default instance.
     151    ///
     152    FdoIEllipticalArcSegment() {};
     153
     154    /// \brief
     155    /// Default destructor.
     156    ///
     157    virtual ~FdoIEllipticalArcSegment() {};
     158};
    95159}}}
     160
     161
     162
    96163
    97164
