Changes between Version 1 and Version 2 of CsMapRfc4
- Mar 16, 2011, 4:06:47 PM (13 years ago)
CsMapRfc4
v1 v2 19 19 20 20 == Overview == 21 U Pgrade CS-MAP as necessary to compile and run in 32 bit and 64 bit mode using the Visual Studio 2010 compiler.21 Upgrade CS-MAP as necessary to compile and run in 32 bit and 64 bit mode using the Visual Studio 2010 compiler. 22 22 23 23 == Motivation == … … 28 28 29 29 == Implications == 30 It is not intended to affect existing compilation performance in any way, just add 2010 to the list of tested compilers. 30 It is not intended to affect existing compilation performance in any way, just add 2010 to the list of tested compilers. The existin solution file will be retained, although renamed to indicate that it is a VS2008 compatible file. 31 31 32 Test Plan¶ 32 == Test Plan == 33 33 The results of omcpileing using VS2010 will be tested using the CS-MAP ConsoelTestCpp program at the 32 and 64 bit levels. 34 34 35 35 == Funding/Resources == 36 Resources to be provided by A Utodesk.36 Resources to be provided by Autodesk.
