Changes between Version 16 and Version 17 of UsersWikiInstall
Jun 20, 2012, 1:46:06 AM (12 years ago)
Mike Taves
add TOC; work on the spacings; PostgreSQL 9.0 required for PostGIS 2.1
  • UsersWikiInstall
    v16 v17
     1[[TOC]]
    12= PostGIS Install Guide =
    2 [wiki:UsersWikiPostgreSQLPostGIS PostGIS/PostgreSQL and other dependency matrix]
    3    This is a matrix that defines recommended versions of core dependencies for each version of PostGIS
    4 The following is a guideline to install PostGIS onto most UNIX-like systems from either prebuilt packages (where maintained) or source.
     3The following is a guideline to install PostGIS onto various operating systems from either prebuilt packages (where maintained) or source.
     5See the [wiki:UsersWikiPostgreSQLPostGIS PostGIS/PostgreSQL and other dependency matrix] that defines recommended versions of core dependencies for each version of PostGIS.
    56
    67== PostGIS 2.1 (still in development) ==
    7 No PostGIS 2.1 guides available yet, but there are currently no new dependencies
    8 either except to take full advantage of new interruptibility feature you need GEOS 3.4.0+ and you need at least GEOS 3.3 to run
    9 PostGIS 2.1
     8No install guides are available for PostGIS 2.1, so for now just follow the 2.1 guides (from source versions).
    109
    11 For now just follow the 2.1 guides (from source versions)
     10Keep in mind a few dependencies for PostGIS 2.1:
     11 * PostgreSQL 9.0 or later
     12 * At least GEOS 3.3, but preferably GEOS 3.4.0 for the new interruptibility feature
     13
    1214== PostGIS 2.0 ==
    1315 * Debian 6.0 (''squeeze'') - uses PostgreSQL 8.4
    1416   * [wiki:UsersWikiPostGIS20Debian60src from source]
    15  * Debian 7.0 (''wheezy'') - uses PostgreSQL 9.1
     17
     18* Debian 7.0 (''wheezy'') - uses PostgreSQL 9.1
    1619   * [wiki:UsersWikiPostGIS20Debian70src from source]
     20
    1721 * Fedora 16 (''Verne'')
    1822   * [wiki:UsersWikiPostGIS20Fedora16pgdg using PGDG YUM/RPM packages]
     23
    1924 * Ubuntu 10.04 LTS (''lucid'') - uses PostgreSQL 8.4
    2025   * [wiki:UsersWikiPostGIS20Ubuntu1004src from source]
    2127 * Ubuntu 11.10 (''oneiric'') - uses PostgreSQL 9.1
    2228   * [wiki:UsersWikiPostGIS20Ubuntu1110src from source]
    2329   * [wiki:UsersWikiPostGIS20Ubuntu1110pkgSharpie from packages, using ppa:sharpie]
     30
    2431 * Ubuntu 12.04 (''precise'') - uses PostgreSQL 9.1
    2532   * [wiki:UsersWikiPostGIS20Ubuntu1204 hacky hybrid approach]
    2936   * [wiki:DevWikiWinMingW64 Compiling PostGIS 2.0 under Windows using MinGW-w64/Msys]
    3037
    31
    3238== PostGIS 1.5 ==
    3339 * RHEL / Fedora / CentOS:
    3642   * UsersWikiPostgisRpmInstallation
    3743   * [wiki:UsersWikiPostgisRpmInstallation PostGIS RPM Installation] (older)
     44
    3845 * Debian 6.0 (''squeeze'') - uses PostgreSQL 8.4
    3946   * [wiki:UsersWikiPostGIS15Debian60pkg using prebuilt packages]
    4047   * [wiki:UsersWikiPostGIS15Debian60src from source]
     48
    4149 * Ubuntu 10.04 LTS (''lucid'') - uses PostgreSQL 8.4
    4250   * [wiki:UsersWikiPostGIS15Ubuntu1004src from source]
     51
    4352 * Ubuntu 11.10 (''oneiric'') - uses PostgreSQL 9.1
    4453   * [wiki:UsersWikiPostGIS15Ubuntu1110pkg using prebuilt packages]
