Changes between Version 16 and Version 17 of ossimPreferenceFile
Feb 9, 2014, 10:32:32 PM (10 years ago)
domtheos
  • ossimPreferenceFile
    v16 v17
    77This is an example of an ossim preference file.[[BR]][[BR]]
    88
    9 Note that it has unix style paths.  On windows you should use windows paths.[[BR]]
     9Note that it has [https://www.idigbio.org/wiki/index.php/TCNs unix] style paths.  On windows you should use windows paths.[[BR]]
    1010e.g.: elevation_source1.filename: D:\elevation\srtm\1arc[[BR]]
    1111[[BR]][[BR]]
    1212Note also that you can name the file anything you want.  OSSIM finds the file via the environment variable OSSIM_PREFS_FILE which should point to the name of your file.  Alternatively you can use the "-P" option in any ossim application and point to the preference file.[[BR]]
    1313e.g.:   <some-ossim-application> -P ~/ossim_preferences <application-args>
    14 [http://www.awanirentcar.com Sewa mobil jakarta], [http://kiosauto.com Aksesoris mobil], [http://www.tokobungasabana.com Toko bunga online bandung], [http://littletods.com/en/content/4-perlengkapan-bayi Jual perlengkapan bayi], [http://vamostech.com/gps-tracking Gps tracking motor]
     14[http://www.awanirentcar.com/pricelist Sewa mobil jakarta], [http://kiosauto.com Aksesoris mobil], [http://www.tokobungasabana.com Toko bunga online bandung], [http://vamostech.com/gps-tracking Gps tracking motor]
    1515
    1616
