Changes between Version 3 and Version 4 of img2rr
Oct 16, 2010, 5:54:25 AM (14 years ago)
pborissow
  • img2rr
    v3 v4
    1212== Options ==
    1313{{{
     14  --compression-quality    Compression quality varies from 0 to 100, where 100
     15                           is best.  Currently only for JPEG compression
     16  --compression-type       Compression type can be: NONE, JPEG, PACKBITS, or
     17                           DEFLATE
     18  --create-histogram       Computes a histogram.
     19  --create-histogram-fast  Computes a histogram in fast mode which samples
     20                           partial tiles.
     21  --create-mask            Computes a mask which applies to an image for cutting
     22                           off black specks around the image.
    1423  --disable-elev           Will disable the elevation
    1524  --disable-notify         Takes an argument. Arguments are ALL, WARN, NOTICE,
    1827                           line.  All argument are case insensitive.  Default is
    1928                           all are enabled.
     29  --disable-plugin         Will disable the plugin loader
     30  --histogram-bins         Number of histogram bins.   This will override the
     31                           default for scalar type.  Also this will force a
     32                           separate pass.
     33  --histogram-max          Maximum histogram value to use.  This will override
     34                           the default for scalar type.  Also this will force a
     35                           separate pass.
     36  --histogram-min          Minimum histogram value to use.  This will override
     37                           the default for scalar type.  Also this will force a
     38                           separate pass.
     39  --histogram-r0           Forces create-histogram code to compute a histogram
     40                           using r0.  If source image has reduced resolution
     41                           sets built in a separate pass will be made at r0.
    2042  --list-entries           Lists the entries within the image
    2143  --ossim-logfile          takes a logfile as an argument.  All output messages
    2244                           are redirected to the specified log file.  By default
    2345                           there is no log file and all messages are enabled.
    24   -K                      specify individual keywords to add to the preferences
     46  --set-property           key:value NOTE: separate key value by a colon.
     47                           Deprecated, use --writer-prop instead.
     48  --tile-size              Defines the tile size for the supported overview
     49                           handler.
     50  --version                Outputs version information.
     51  --writer-prop            Adds a property to send to the writer. format is
     52                           name=value
     53  -K                       specify individual keywords to add to the preferences
    2554                           keyword list: name=value
    26   -P                      specify a preference file to load
    27   -T                      specify the classes to trace, ex:
    28                            ossimInit|ossimImage.*
     55  -P                       specify a preference file to load
     56  -T                       specify the classes to trace, ex:
     57                           ossimInit|ossimImage.*
    2958                           will trace ossimInit and all ossimImage classes
     59  -V or --version          Display version information.
    3060  -a or --include-fullres  Wants to include full res dataset as well as reduced
    3161                           res sets.
     62  -d                       Write overview to directory specified.
    3263  -e or --entry            Give the entry(zero based) to build an overview for.
    3364  -h or --help             Shows help
     65  -o                       Write overview to file specified.  If used on a
     66                           multi-entry file, given "foo.ovr" you will get:
     67                           "foo_e0.ovr"
     68  -r or --rebuild          Rebuild overviews even if they are already present.
     69  -s                       Stop dimension for overviews.  This controls how
     70                           many layers will be built. If set to 64 then the
     71                           builder will stop when height and width for current
     72                           level are less than or equal to 64.  Note a default
     73                           can be set in the ossim preferences file, setting the
     74                           keyword "overview_stop_dimension".
     75  -t or --type             see list at bottom for valid types. (default =
     76                           ossim_tiff_box)
    3477}}}
     78
     79== Overview Types ==
     80Valid overview types include:
     81 * ossim_tiff_box
     82 * ossim_tiff_nearest
     83 * ossim_kakadu_nitf_j2k
    3584
    3685== Examples ==
