Changes between Version 6 and Version 7 of icp
- Oct 16, 2010, 10:08:11 AM (14 years ago)
icp
v6 v7 2 2 3 3 The ossim-icp application is an image conversion tool used to translate an input image to another format (e.g. TIF to JPG). It can also be used to crop, band select and convert scalar type. If you wish to resample or reproject your data, please use [wiki:orthoigen] instead. You can find a complete list of supported formats [wiki:formats here]. 4 5 The iView GUI application operates as a viewer and a way to set up parameters for icp. icp can be called from the command line or from an application - e.g. iView.6 4 7 5 == Usage ==
