Changes between Version 6 and Version 7 of gdalplugin
- Oct 16, 2010, 9:51:01 AM (14 years ago)
gdalplugin
v6 v7 11 11 }}} 12 12 13 Note that there is some overlap between formats supported via GDAL and the other plugins (e.g. jpeg, png, nitf, tif, etc.). Let's take PNG as an example. The [wiki:pngplugin PNG Plugin] uses ossim_png. GDAL's png driver is called gdal_PNG. In [wiki:orthoigen] you can specify which writer to use . Example:13 Note that there is some overlap between formats supported via GDAL and the other plugins (e.g. jpeg, png, nitf, tif, etc.). Let's take PNG as an example. The [wiki:pngplugin PNG Plugin] uses ossim_png. GDAL's png driver is called gdal_PNG. In [wiki:orthoigen] you can specify which writer to use using the -w argument. Example: 14 14 {{{ 15 15 ossim-orthoigen -w ossim_png input.tif output.png … … 18 18 ossim-orthoigen -w gdal_PNG input.tif output.png 19 19 }}} 20 If the writer argument is not specified, OSSIM will use whichever plugin appears first in the ossim_prefs file.
