| 2 | |
| 3 | This is currently only implemented in the ossim_qt(qt3) module. |
| 4 | |
| 5 | image_window->Edit->View |
| 6 | |
| 7 | In the View Geometry dialog click "Identity", then hit "Apply button". That's it... |
| 8 | |
| 9 | To switch back do the opposite. |
| 10 | image_window->Edit->View |
| 11 | In the View Geometry dialog click "Map", then hit "Apply button". |
| 12 | |
| 13 | Notes: |
| 14 | 1. You can zoom between rlevels only (no infinite zoom). |
| 15 | 1. Tracking cursor will track still with other images. |
| 16 | 1. You will see at bottom right of images you now get real full res pixel location. |
| 17 | 1. Also bottom right you should see: Mode:Identity |
