Changes between Version 8 and Version 9 of Solaris10Build
Mar 15, 2010, 3:23:53 PM (14 years ago)
alight
  • Solaris10Build
    v8 v9
    55Installing the Source Code:
    66
    7 This guide assumes that you are running as root for the duration of the install.
     7This guide assumes that you are running as root for the duration of the install, and all steps were done on a clean install of Solaris 10.
    88
    99* Make sure you have these files in ~/ :
    158158}}}
    159159
    160 Instructions for building the OSSIM distribution on Solaris 10 systems.  This tutorial tracks an install of the OSSIM distribution from July 2008 on a freshly installed version of Solaris 10.  This tutorial assumes a build out of a home directory Development folder with default installation at /usr/local as defined by the INSTALL_HERE environmental variable.
     160Instructions for building the OSSIM distribution on Solaris 10 systems.  This tutorial assumes a build out of a home directory Development folder with default installation at /usr/local as defined by the INSTALL_HERE environmental variable.
    161161
    162162The entire OSSIM distribution contains many source directories and dependencies.  Proper set up of the environmental variables used during the build is key to a successful build from source code.
