Changes between Version 29 and Version 30 of MacOSXBuild
Show
12/01/10 10:37:29 (2 years ago)
mlucas17
  • MacOSXBuild
    v29 v30
    5656Create an '''ossim-bashrc''' file under ossim-svn/ to hold these variables:
    5757{{{
    58 export OSSIM_DEPENDENCIES=/Users/Shared/Development/ossim_dependencies
    5958export OSSIM_DEV_HOME=~/ossim-svn/src
    6059export OSSIM_INSTALL_PREFIX=~/ossim-svn/release
     60export OSSIM_DEPENDENCIES=/Users/Shared/Development/ossim_dependencies
     61export PATH=$OSSIM_INSTALL_PREFIX/bin:$PATH
     62LD_LIBRARY_PATH=$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib:$LD_LIBRARY_PATH
     63export LD_LIBRARY_PATH
    6164
    62 DYLD_FRAMEWORK_PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/Frameworks:$OSSIM_DEPENDENCIES/Frameworks:$DYLD_FRAMEWORK_PATH
    63 export PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/bin:$OSSIM_DEPENDENCIES/bin:$HOME
    64 export DYLD_LIBRARY_PATH=$OSSIM_BUILD_DIR/$OSSIM_BUILD_TYPE:$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib:$OSSIM_DEPENDENCIES/kakadu/lib:$OSSIM_DEV_HOME/oms/joms:$DYLD_LIBRARY_PATH:/Developer/qt/lib
    65 export LD_LIBRARY_PATH=$OSSIM_BUILD_DIR:$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEV_HOME/oms/joms
     65# For MAC’s add the following,
     66DYLD_FRAMEWORK_PATH=$OSSIM_INSTALL_PREFIX/Frameworks:$OSSIM_DEPENDENCIES/Frameworks:$DYLD_FRAMEWORK_PATH
     67DYLD_LIBRARY_PATH=$OSSIM_INSTALL_PREFIX/lib:$OSSIM_DEPENDENCIES/lib:$OSSIM_DEPENDENCIES/kakadu/bin:$WXMAC_HOME/lib:$PG_HOME/lib:$OSSIM_DEV_HOME/oms/joms:$DYLD_LIBRARY_PATH:/Developer/qt/lib
    6668
    67 export OSSIM_PREFS_FILE=$OSSIM_DEV_HOME/../ossim_preferences
    68 export OSG_FILE_PATH=/data/OpenSceneGraph-Data
    69 export OSG_LIBRARY_PATH=/Users/Shared/Development/ossim_dependencies/osg/plugins
     69export DYLD_FRAMEWORK_PATH
     70export DYLD_LIBRARY_PATH
    7071
    7172}}}
    9899 * Get the latest from svn
    99100{{{
    100 cd /Users/Shared/Development
     101cd ~/ossim-svn/src
    101102svn update .
    102103}}}
