Changes between Version 9 and Version 10 of MacOSXBuild
- Jul 3, 2009, 12:43:33 PM (15 years ago)
MacOSXBuild
v9 v10 4 4 5 5 == Binary Installer == 6 The easiest way to get up and running is to install the latest binary installer. During initial development, a fairly recent version of the software will be available at http:// ossim.telascience.org/ossimdata/MacOSX/ . Look for and download the dmg file which will should mount after download. (e.g. ossim_1.6.6rc20.pkg.dmg )Double click the package installer and the libararies and frameworks will be installed in [[standard locations]]:6 The easiest way to get up and running is to install the latest binary installer. During initial development, a fairly recent version of the software will be available at http://download.osgeo.org/ossim/installers/mac/ Look for and download the dmg file which will should mount after download. Double click the package installer and the libararies and frameworks will be installed in [[standard locations]]: 7 7 8 8 == Development == … … 55 55 == Problems with the Build? == 56 56 57 # Make sure you have downloaded the latest ossim_dependencies. The folder should be placed at /Users/Shared/Development/ossim_dependencies .58 # Set the Configuration in xcode to the Release build59 # Do a clean all under build with the ossim project60 # open a terminal and rm -rf /var/tmp/ (forces rebuild of all of the qt gui widgets)61 # under xcode make sure the project is ossim, the target is All, the configuration is Release, Active executable ossimplanet57 # Make sure you have downloaded the latest ossim_dependencies. The folder should be placed at /Users/Shared/Development/ossim_dependencies . 58 # Set the Configuration in xcode to the Release build 59 # Do a clean all under build with the ossim project 60 # open a terminal and rm -rf /var/tmp/ (forces rebuild of all of the qt gui widgets) 61 # under xcode make sure the project is ossim, the target is All, the configuration is Release, Active executable ossimplanet 62 62 63 63 == Package Building ==
