Changes between Version 60 and Version 61 of DavesFedoraCmakeBuildNotes
Oct 14, 2012, 9:14:26 AM (12 years ago)
dburken
  • DavesFedoraCmakeBuildNotes
    v60 v61
    44Author: David Burken
    6 Last modified: 10 October 2012
     6Last modified: 14 October 2012
    88Feedback welcome.  Please send to the ossim mailing list at "ossim-developer AT lists.sourceforge.net" and reference this page.
    375375// Note there's too much junk in the trunk so I usually pull individual modules:
    376376
    377 // Get the code:[[BR]]
     377// Get the code.  Edit script to pull what you want. Contents of svn-co-ossim.sh
     378{{{
     379#!/bin/bash
     380
     381#---
     382# File: svn-co-ossim.sh
     383# Relies on environment variable: OSSIM_DEV_HOME
     384#---
     385
     386if [ -z "$OSSIM_DEV_HOME" ]; then
     387   echo "OSSIM_DEV_HOME environment variable is not set!  Exiting..."
     388   exit
     389fi
     390
     391if [ -d "$OSSIM_DEV_HOME/libwms" ]; then
     392   echo "Updating libwms..."
     393   svn update $OSSIM_DEV_HOME/libwms
     394else
     395   echo "svn co ossimwms..."
     396   svn co https://svn.osgeo.org/ossim/trunk/ossimjni $OSSIM_DEV_HOME/ossimjni
     397fi
     398
     399if [ -d "$OSSIM_DEV_HOME/omar" ]; then
     400   echo "Updating omar..."
     401   svn update $OSSIM_DEV_HOME/omar
     402else
     403   echo "svn co omar..."
     404   svn co https://svn.osgeo.org/ossim/omar $OSSIM_DEV_HOME/omar
     405fi
     406
     407if [ -d "$OSSIM_DEV_HOME/oms" ]; then
     408   echo "Updating oms..."
     409   svn update $OSSIM_DEV_HOME/oms
     410else
     411   echo "svn co oms..."
     412   svn co https://svn.osgeo.org/ossim/trunk/oms $OSSIM_DEV_HOME/oms
     413fi
     414
     415if [ -d "$OSSIM_DEV_HOME/ossim" ]; then
     416   echo "Updating ossim..."
     417   svn update $OSSIM_DEV_HOME/ossim
     418else
     419   echo "svn co ossim..."
     420   svn co https://svn.osgeo.org/ossim/trunk/ossim $OSSIM_DEV_HOME/ossim
     421fi
     422
     423if [ -d "$OSSIM_DEV_HOME/ossimGui" ]; then
     424   echo "Updating ossimGui..."
     425   svn update $OSSIM_DEV_HOME/ossimGui
     426else
     427   echo "svn co ossimGui..."
     428   svn co https://svn.osgeo.org/ossim/trunk/ossimGui $OSSIM_DEV_HOME/ossimGui
     429fi
     430
     431if [ -d "$OSSIM_DEV_HOME/ossimjni" ]; then
     432   echo "Updating ossimjni..."
     433   svn update $OSSIM_DEV_HOME/ossimjni
     434else
     435   echo "svn co ossimjni..."
     436   svn co https://svn.osgeo.org/ossim/trunk/ossimjni $OSSIM_DEV_HOME/ossimjni
     437fi
     438
     439if [ -d "$OSSIM_DEV_HOME/ossim_junkyard" ]; then
     440   echo "Updating ossim_junyard..."
     441   svn update $OSSIM_DEV_HOME/ossim_junkyard
     442else
     443   echo "svn co ossimjunkyard..."
     444   svn co https://svn.osgeo.org/ossim/ossim_junkyard $OSSIM_DEV_HOME/ossim_junkyard
     445fi
     446
     447if [ -d "$OSSIM_DEV_HOME/ossimPlanet" ]; then
     448   echo "Updating ossimPlanet..."
     449   svn update $OSSIM_DEV_HOME/ossimPlanet
     450else
     451   echo "svn co ossimPlanet..."
     452   svn co https://svn.osgeo.org/ossim/trunk/ossimPlanet $OSSIM_DEV_HOME/ossimPlanet
     453fi
     454
     455if [ -d "$OSSIM_DEV_HOME/ossimPlanetQt" ]; then
     456   echo "Updating ossimPlanetQt..."
     457   svn update $OSSIM_DEV_HOME/ossimPlanetQt
     458else
     459   echo "svn co ossimPlanetQt..."
     460   svn co https://svn.osgeo.org/ossim/trunk/ossimPlanetQt $OSSIM_DEV_HOME/ossimPlanetQt
     461fi
     462
     463if [ -d " $OSSIM_DEV_HOME/ossimPredator" ]; then
     464   echo "Updating ossimPredator..."
     465   svn update $OSSIM_DEV_HOME/ossimPredator
     466else
     467   echo "svn co ossimPredator..."
     468   svn co https://svn.osgeo.org/ossim/trunk/ossimPredator $OSSIM_DEV_HOME/ossimPredator
     469fi
     470
     471if [ -d "$OSSIM_DEV_HOME/ossim_package_support" ]; then
     472   echo "Updating ossim_package_support..."
     473   svn update $OSSIM_DEV_HOME/ossim_package_support
     474else
     475   echo "svn co ossim_package_support..."
     476   svn co https://svn.osgeo.org/ossim/trunk/ossim_package_support $OSSIM_DEV_HOME/ossim_package_support
     477fi
     478
     479if [ -d "$OSSIM_DEV_HOME/ossim_plugins" ]; then
     480   echo "Updating ossim_plugins..."
     481   svn update $OSSIM_DEV_HOME/ossim_plugins
     482else
     483   echo "svn co ossim_plugins..."
     484   svn co https://svn.osgeo.org/ossim/trunk/ossim_plugins $OSSIM_DEV_HOME/ossim_plugins
     485fi
     486
     487if [ -d "$OSSIM_DEV_HOME/ossim_qt4" ]; then
     488   echo "Updating ossim_qt4..."
     489   svn update $OSSIM_DEV_HOME/ossim_qt4
     490else
     491   echo "svn co ossim_qt4..."
     492   svn co https://svn.osgeo.org/ossim/trunk/ossim_qt4 $OSSIM_DEV_HOME/ossim_qt4
     493fi
     494}}}
     495
     496$ svn-co-ossim.sh[[BR]]
    378497$ cd /work/osgeo[[BR]]
    379 $ svn co http://svn.osgeo.org/ossim/omar omar[[BR]]
    380 $ svn co http://svn.osgeo.org/ossim/trunk/oms oms[[BR]]
    381 $ svn co http://svn.osgeo.org/ossim/trunk/ossim ossim[[BR]]
    382 $ svn co http://svn.osgeo.org/ossim/trunk/ossimGui ossimGui[[BR]]
    383 $ svn co http://svn.osgeo.org/ossim/trunk/ossimjni ossimjni[[BR]]
    384 $ svn co http://svn.osgeo.org/ossim/trunk/ossim_package_support ossim_package_support // If you haven't already.[[BR]]
    385 $ svn co http://svn.osgeo.org/ossim/trunk/ossim_plugins ossim_plugins[[BR]]
    386 $ svn co http://svn.osgeo.org/ossim/trunk/ossim_qt4 ossim_qt4[[BR]]
    387 $ svn co http://svn.osgeo.org/ossim/trunk/libwms libwms[[BR]]
    388498
    389499$ mkdir build // "out of source" build dir[[BR]]
