Changes between Version 2 and Version 3 of maestro/UserGuides/VectorLayerEditor
- Jan 15, 2010, 12:41:17 PM (14 years ago)
v2 v3 23 23 }}} 24 24 This will hide all items where the value of the ID column is less than 100. 25 If you click the "..." button at the end, you will see an incomplete editor that basically gives you a bigger text area to type in.25 If you click the "..." button at the end, you will see an editor that helps you type in values, column names and values. 26 26 27 27 A feature in MapGuide can also have a link. If the user pauses the mouse over a feature with a link, they will recieve a message that indicates they can open the link. If you type in a string like: … … 38 38 CONCAT(CONCAT("URL", '?ID='), "ID") 39 39 }}} 40 The two statements produce the same results, but the latter is required for some providers. If you click the "..." button at the end, you will see an incomplete editor that basically gives you a bigger text area to type in.40 The two statements produce the same results, but the latter is required for some providers. If you click the "..." button at the end, you will see an incomplete editor that helps you type in values, column names and values. 41 41 42 42 The "Tooltip" field is subject to the same rules as the "Link" field, but will result in a tooltip the user can see. You may build a html fragment rather than a simple string. Such a html fragment can include an image like this: … … 67 67 A common use of rules, is to create a theme, where objects are color coded according to a value, eg. parcels color code by property value. 68 68 69 The "Theme" button is not created yet, but once done, it will be able to create gradient color set. If you want to help out, you can implement such a dialog and submit it to the Maestro project.69 The "Theme" button will show you a dialog that can, among other things, generate a rule list with gradient colors, based on a property value. 70 70 71 71 The label field allows you to enter a label that is displayed for the features. You can enter expressions format labels, using data from the feature.
