Changes between Version 3 and Version 4 of maestro/Translation
- Dec 12, 2009, 5:17:58 PM (14 years ago)
maestro/Translation
v3 v4 6 6 7 7 == Prerequisites == 8 * !MapGuide Maestro 1.0.9 r4 387or later [wiki:maestro/Downloads Download]8 * !MapGuide Maestro 1.0.9 r4431 or later [wiki:maestro/Downloads Download] 9 9 * Microsoft .Net Framework 2.0 [http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5 Download] (Should be installed) 10 10 * Microsoft .Net 2.0 SDK [http://www.microsoft.com/downloads/details.aspx?FamilyID=fe6f2099-b7b4-4f47-a244-c96d69c35dec Download] (Included in Visual Studio 2005 or newer) … … 57 57 }}} 58 58 59 Remember that localization only works with Maestro 1.0.9 r4 387or newer.59 Remember that localization only works with Maestro 1.0.9 r4431 or newer. 60 60 61 61 You can also install Visual Studio 2009 (Express is fine), and build the solution, which will create the file. … … 65 65 If you have no such set, skip this section. 66 66 67 Prior to r4 387all files for a language was placed in a folder, and loaded at runtime.67 Prior to r4431 all files for a language was placed in a folder, and loaded at runtime. 68 68 Before you attempt this, make sure that the folder you wish to upgrade only contains a single language, 69 69 also make sure you have a backup of the files.
