Changes between Version 5 and Version 6 of maestro/MaestroAPI
Dec 2, 2008, 4:49:20 AM (15 years ago)
ksgeograf
  • maestro/MaestroAPI
    v5 v6
    1717 *  '''[wiki:maestro/MaestroAPI/samples/RuntimeMap Utilizing RuntimeMap via Maestro API]''' - a short example of getting to RuntimeMap instance.
    1818 *  '''[wiki:maestro/MaestroAPI/samples/AddInitialLayer Adding a layer before startup via Maestro API]''' - an example of how to add a layer to map before the viewer loads.
    19  *  '''[wiki:maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout Creating a temporary WebLayout with customized zoom]''' - shows how to modify an existing WebLayout to select the initial zoom level.
     19 *  '''[wiki:maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout Creating a temporary WebLayout with customized zoom]''' - shows how to modify an existing !WebLayout to select the initial zoom level.
    2020 *  '''[wiki:maestro/MaestroAPI/samples/BrandNewSample Add your cool sample here]''' You must be logged in with an [http://www.osgeo.org/osgeo_userid/ OSGeo ID] before you can edit the page.
