Changes between Version 2 and Version 3 of ReleaseReadiness22RC1
Jul 10, 2010, 9:13:00 AM (14 years ago)
trevorwekel
  • ReleaseReadiness22RC1
    v2 v3
    3636
    3737== Defects ==
     38=== Outstanding ===
    3839||'''Ticket'''||'''Status'''||'''Tentative[[BR]]Completion'''||'''Resource'''||'''Notes'''||
     40
     41||Ticket #1021 Avoiding login window in an application using flexible fusion weblayout ||Reopened||TBD||volunteer?|| ||
     42||Ticket #1096 <coordinates> tag in generated KML does not follow spec ||Reopened||TBD||volunteer?|| ||
     43||Ticket #1196 !MapGuide unresponsive using GDAL provider (related to ticket #462)||New||TBD||volunteer?|| ||
     44||Ticket #1263 wrong scale values with tiles maps ||New||TBD||volunteer?|| ||
     45||Ticket #1274 Right button context menu doesn't work in Opera or Chrome ||New||TBD||volunteer?|| ||
     46||Ticket #1278 Apache crashes under load ||New||TBD||volunteer?|| Need Apache 2.2.14(+)||
     47||Ticket #1308 out of bounds tile requests are rendered and persisted||New||TBD||volunteer?|| ||
     48||Ticket # ||Unassigned||TBD||volunteer?|| ||
     49||Ticket #1351 !CreateSession can generate invalid session ids ||New||TBD||Chris|| ||
     50||Ticket #1368 ACE:init missing in !MapGuideCommon lib ||New||TBD||Bruce|| ||
     51||Ticket #1369 Problem with !MapGuide and Oracle Spatial (FDOKingOracle) in linux ||New||TBD||volunteer?|| ||
     52||Ticket #1370 Can't login using 2.1 preview ||Assigned||TBD||Jackie|| ||
     53||Ticket #1376 Error with !SetResource ||New||TBD||volunteer?|| ||
     54||Ticket #1378 Cannot connect to SQL Server 2008 - 2.2 Beta 1 ||New||TBD||volunteer?|| ||
     55||Ticket #1380 Mapguide 2.2 beta on Linux fails to setup locale from system ||New||TBD||Trevor|| ||
     56||Ticket #1382 Mapguide 2.2 beta. Undefined symbols in FDO PostGIS e FDO PostgreSQL/PostGIS providers ||New||TBD||Trevor|| ||
     57||Ticket #1388 !MgMap.Create causes crash of 64 bit Web Extensions on Windows ||New||TBD||Jackie|| ||
     58||Ticket #1393 Maestro does not launch from installer ||New||TBD||Jackie|| ||
     59||Ticket #1396 Feature join rendering problems (possible explanation inside...) ||New||TBD||Bruce|| ||
     60||Ticket #1397 When the length of !TaskPane url is less than 8, there will be a exception ||New||TBD||volunteer?|| ||
     61||Ticket #1400 WFS using King.Oracle FDO Provider||New||TBD||volunteer?|| ||
     62=== Fixed ===
    3963||Ticket #1004 Release 2.1.0 (Beta) build in linux_redhat5 not work||Completed||Mar 30||Trevor|| ||
    40 ||Ticket #1359 Arbitrary XY-M maps are problematic in Fusion||Completed||June 24||Mike Adair||Mike has submitted a fix to Fusiont ||
     64||Ticket #1359 Arbitrary XY-M maps are problematic in Fusion||Completed||June 24||Mike Adair||Mike has submitted a fix to Fusion ||
     65
    4166
    4267== Functional Validation ==
