Changes between Version 1 and Version 2 of Release/2.5.1/Notes
- Aug 14, 2013, 8:18:56 PM (11 years ago)
Release/2.5.1/Notes
v1 v2 76 76 Windows RT (ie. Windows 8 on ARM devices) is not a supported platform for installing MapGuide Open Source 77 77 78 == Installer Notes == 79 80 * The windows installer is an '''in-place''' upgrade to MapGuide Open Source 2.5, you cannot have 2.5 and 2.5.1 installed side-by-side and you must uninstall 2.5 before installing 2.5.1. Use the InstantSetup bundle if side-by-side installs are required. Be sure to back up any data and applications before carrying out the new installation. 81 * On linux, the install path is {{{/usr/local/mapguideopensource-2.5.1}}} and the FDO install path is {{{/usr/local/fdo-3.8.0}}}. You must uninstall 2.5 before installing 2.5.1. Be sure to back up any data and applications before carrying out the new installation. 82 78 83 == API Changes == 79 84
