Changes between Version 9 and Version 10 of Release/2.4/Notes
Apr 24, 2012, 8:40:57 AM (12 years ago)
jng
  • Release/2.4/Notes
    v9 v10
    2323||Windows Vista||Maybe+||Maybe+||
    2424||Windows 7||Yes||Yes||
    25 ||Windows Server 2008||N/A||Yes||
     25||Windows Server 2008||Yes+||Yes+||
     26||Windows Server 2008 R2||N/A||Yes||
    2627
    2728* IIS configuration will probably not work. Apache config should work due to its self-contained nature
    7677Please observe the updated software requirements if you are using .net and/or IIS configuration:
    7778
    78  * IIS (all versions) require FastCGI for IIS to be installed. See [http://www.iis.net/download/FastCGI this link] for more information
     79 * IIS (all versions) require FastCGI for IIS to be installed.
     80   * For IIS6 and below, download and install the FastCGI extension from [http://www.iis.net/download/FastCGI this link]
     81   * For IIS7 and above, you can install FastCGI by enabling the CGI feature of your IIS installation. See [http://learn.iis.net/page.aspx/246/using-fastcgi-to-host-php-applications-on-iis/#EnableFastCGI this link] for more information.
    7982 * The supported .net Framework version for the MapGuide .net API is '''4.0'''
    8083   * For IIS6 and below, the installer will still set the ASP.net version to '''2.0.50727'''. You will have to manually change the ASP.net version to '''4.0.30319''' post-install
